My final design of my reverse gear select!
Posted this on Thingiverse for those who want to print there own.
http://www.thingiverse.com/thing:3760108
If you do lets see some pictures.
Larger handle for the reverse gear select lever.
Will fit all models of the Can Am Ryker.
This will make it much easier to change gears either
using you foot or your hand.
I also lifted the gear lever off the spine and rotated it back further,
This is completely optional on your part.
I also added a washer in front of the handle so it would not
slide over the raised portion of the shaft, again optional.
