Mirror housing vibrates - any fixes??
Motogordo
My left mirror housing vibrates. When I put scotch tape on the top between the front and back panels, it stops. What can I do. The dealer said there is no adjustment for that.2021-10-17 10.16.2021 001.jpg
Oct. 18, 2022
I had to put scotch tape on my left mirror housing to keep it from vibrating. The dealer said there is no fix for that2021-10-17 10.16.2021 001.jpg .
Oct. 18, 2022
I had to put scotch tape on my left mirror housing to keep it from vibrating. The dealer said there is no fix for thatView attachment 192997 .
A lot of the BRP clips etc. are not so good, as many people already know. The right mirror housing doesn't vibrate. Does that mean one of the clips is not good on the left side ?
Motogordo
My problem is the tupperware housing for the mirrors is where the vibes are coming from. The black panel and the red panel are not tight enough and there is no adjustment for that, so the dealer says.
Oct. 18, 2022
Motogordo
I think you need to describe your issue more clearly.
Oct. 18, 2021
When I start to drive, I get vibration sounds from the mirror mount. Not referring to the mirrors themselves but the two part housing is what is vibrating. If I squeeze the front and the back panel of the mirror housing a little, then vibrating stops.
Oct. 18, 2021
Did you watch the video in the link I gave you? That product will fix the mirror on the 2020 / 21 F3T and L
