mirror relocators
rays hell
Does anyone know if Lamonster's mirror relocators will work on an F-3T ?
I would love for the mirrors to be more functional than hidden behind the handle bars.
Tricled
I have the same trike.. look at the Tricled mirrors
I did look at Tricled mirrors, but the problem is where the mirrors are located.
Lamonster's mirror relocators and top caps you can put the mirrors on the handle bars.
I don't want 2 sets of mirrors and a gaping hole where I removed the factory set.
I did not want two sets of mirrors on my F3S either but in the end the combination worked very well. I use the OEM mirrors to see who is behind me and the handlebar mirrors to see who is in my blind spot without having to turn my head. My handlebar mirrors consisted of Lamonster F3 Top Cap for RAM mount-Pair-SE and Bikemaster GP Composite Mirrors (left side 601145, right side 601146). The handlebar mirrors detract from the bike's appearance but they are very functional and I love them. The stem on the mirrors does not block my line-of-sight to the OEM mirrors and I am 5'7" tall.
Plugger2
Tricked.com has wide view mirrors that just goes over original mirrors.They are great as theylet u see right along side of yur spyder. They are a new product .
Lamonster relocated top mirrors and the stock mirrors combination looks and functions are fine. I raised my handlebars so the stock mirrors are blocked by my hands and the controls.
Tricled Mirrors
I just installed Tricled expanded view mirrors on my 2017 F3L and they are
well worth the money. Clean the mirrors and clean them again, carefully line
them up and stick them on.
Dray
Mirror Relocate
Installed a set of Lamonster relocate on the wife's 2015 F3S. love them. Please make a set for the F3T. I hate those shacking mirrors. all ready have your handle bar mounted mirrors. Just want to remove the stock one. Clean the bike up a little more. Keep up the great work Lamonster for us.
Joe from Squared Away has the shaking mirror fix. Called the Wedgie. Did mine and are rock solid.
I have Lamont's mirror relocators on my 2017 F3T. No problems installing and it's nice to see something other than my elbows. Still thinking about whether I want to remove the stock mirrors and what to do about the hole that's going to be left behind if I do.
If I’m not in error, the OEM mirrors also have the turn signal. If those mirrors are removed, not only is there a hole, but there is no turn signal. It was my understanding the Lamonster Garage had a plug n play light which fills the mirrorless void on all but the Ltd. At last contact with Lamont and crew, there was no immediate plan to develop an alternative to fit the Limited. I also inquired oh lots of different companies and suppliers about such a product, but was told they had no interest.
I added the tricled wide angle mirrors back a couple years ago. They do improve the view for both of us. They stick on right over the existing mirrors. Have never had a problem with them coming loose.
I can't wait to try my Tricled mirror's. My wife got me some Christmas of 2017 and they disappeared. Well I was painting the grand kids bedroom this weekend and guess what I found under our grandson's bed.
I was considering removing the mirrors, not the whole housing. I agree, there's nothing to plug the hole if the housings are removed... but there are options if one only removes the mirrors. My thoughts run towards a fitted Kydex sheet, maybe incorporating LED turn indicators slaved to the current turn signals on the mirror housings.
Interesting idea. I’d always wanted to just get rid of that hunk of plastic. I hadn’t thought of the the a turn signal “etched” or cut into it. If you actually do do it, I’d certainly be interested in the results.
