Modifications recommendation from those who tour on the Spyder
herring
First, I want to thank everyone for the assistance during my first year of ownership. My wife and I purchased a 2025 Spyder RT LTD in June 2025. To date, we have 5,500 miles and counting. I am asking for advice on modifications before heading on an extended trip. So far, we have done the following:
  • Passenger armrest
  • Driver back rest
  • Backup camera
  • LidLox helmet locks
  • Baja Ron sway bar
  • Can am frunk and side luggage
  • Driver water bottle holder. (I have a passenger one installed, but will replace it as it does not function well)
  • Purchased a Battery Tender charging/Jump start as well as a portable air compressor
  • Cardo communication system
Items that I'm considering
  • Apple CarPlay - Still inconsistent. I can get it to work most of the time, thinking about adding a GPS
  • Radiator - I've heard of users reporting damage when traveling. Thinking about grills
  • Shocks - The initial cost + an estimated 500.00 installation cost. Are they worth the investment?
  • Additional lighting for safety
Any input from those who redid for an extended period of time would be appreciated.
I'm all about additional lighting. I have gone to LEDs front and rear, an extra bright, high mount brake light. Also, high mounted driving lights.
Safe travels...........
Suspension for sure 2 up and it's so easy to install on the front, while not hard the rear one on the RT need a few pieces of plastic removed for access....still only a bolt off...bolt on thing....quite a few YouTube
I have a GPS for that exact reason....and sometimes tower are not closed enough CarPlay need them unless you get the offline map before hand..
Radiator grill are great as well at keeping bugs out for the most part.
I'm also a huge fan of more lights to be seen....they still don't always see us but I'm sure it helps...
Apple CarPlay was a bit flaky when CAN-AM first got it working on my 2024 Spyder RT S2S, but the only time I've really had a problem with it was in a narrow canyon with limited cell phone signal. That's expected, of course, since it's based on your phone's ability to connect.
I bought my 2024 Spyder before CarPlay was working, so I also bought a Garmin Zumo XT GPS. The Garmin Zumo line was designed for motorcycle use and is weather resistant. The power connection port has a rubbery cover that snaps into place so you can use it even in the rain, but it is "open" when the power cable is connected.
It looks like the latest version is the Garmin Zumo XT3.
  • Passenger armrest
  • Driver back rest
  • Backup camera
  • Baja Ron sway bar
Go play in rush hour traffic to get comfortable with that, as on an extended trip you will be in heavy traffic once in a while, which requires a heighten level of attention for sometimes an extended period.
I have both an Android Auto screen and a Garmin XT GPS. Dash Cam, phone mount and cup holder.
If your rear tire is the Kenda that came on it new, you probably only have about 4K miles left B4 its bald!
General has a good solution to that. I have installed three of those now and will do a forth on my Northern Spyder this summer. One was for my in-lays 2014. Bit of a job, but at 81 I can still get it done. I bought the all tools needed except the jack, which I borrow from friends. I strap the front tires down to my ramped 2x6 boards used for oil changes. I dump the front Kenda's also. https://www.amazon.com/dp/B0B6JR9C75?ref=ppx_yo2ov_dt_b_fed_asin_title
If you're two up on an extended trip not pulling a trailer then I would seriously consider the Show Chrome luggage rack along with a suitable weatherproof bag to strap to it. It will make a difference in your luggage capacity. You'll need to upgrade your trunk gas spring as well. I used this one and its excellent. You'll appreciate it even without anything on your trunk lid. As far as a passenger cup holder check out Butler Cups. They do not make a bolt on kit for the 2020+ RT but I bought a three piece passenger bracket and mated it to Ram components to create my own. Don't forget to get the cup and the circular holder that mates to the bracket. See pictures. Make sure you have a method to recharge your Cardo units on the bike. I've found on long days it pays to recharge the units while at lunch to avoid the batteries going dead toward the end of the day. Lastly I've found this dash bag really useful for keeping all kinds of things handy. Its waterproof so no need to worry about things getting wet.
Thank you. Which brake light did you install? I was looking at this light for the top case from SlingMods
Thank you. I have driven in rush hour traffic in a larger city without any issues. Due to the increased visibility I'm actually more comfortable on the Spyder than in my car.
Thank you. I was surprised at the estimated cost for installation of shocks. Which brand did you install?
Thank you. I was thinking about the luggage rack for extra storage. (As well as the installation of the heavier shock for the rear trunk)
I checked out the dash bag. Does this interfere with the raising and lowering of the fairing?
