Motogordo
Has anyone mounted any of the portable Garmin 255W's on their Spyder ? I haven't found a place to put it. I also haven't found a simple way to get the 12 volts up front.
Gordon
Sept 15, 2011,
I finally installed my Garmin Nuvi 1450 last night. I have a battery tender wire coming directly from the battery, which I use to continuosly to keep the battery charged. I bought a 6 ft. cable with a 12 volt in line female connector and the matching battery tender plug on the other. I just connect the Garmin cable with the 12 volt cable and I hang the GPS on the left side of the windshield. It works fine there, except I have the same problem with all the GPS's on the cycles that everyone else seems to have. Glare. I guess all of them need a type of surrounding shield to keep the sun off. At night, there is no problem. Any suggestions ?
Gordon
Gordon
Sept 15, 2011,
Gordon
