Threads on lifting your spyder seem to always discuss using motorcycle/atv lifts. I need to lift the front end with an old fashion floor jack to get wheels off of floor for working with a arm. Is there a jacking point on the front of my 2015 ST(s) that I can use?
I'll assume that your Floor jack will slide under the front .... if not put the front tires on 1 1/2 pieces of wood ..... Then put the arm under the center of the Spyder and make sure it's positioned Directly under the MAIN frame it runs from front to rear ( until it gets to the rear swing arm ) ..... Raising the front needs a bit more care, it will be balanced, but before you work on anything put JACK stands ( or similar ) under the front suspension arms. What you want to do to to the Spyder will determine how high it needs to be ..... good luck .... Mike :thumbup:
thanks Mike. I only need to relieve pressure on lower shock bolts so that I can reverse them and install Lamonster tow hooks.
I did not understand your last message.....what do I attach to the handlebar ends?
I slide my floor jack in from the side. If I'm lifting the front then I will place it at the front of the center frame and lift from there, I do the opposite if I'm lifting the rear. I never lift the entire bike at one time.
My husband passed this past February, so I am on my own as far as working on my F3-T. I read the posts, but I am a little confused. I want to check the drive belt for possible damage. The city laid down tar gravel and I couldn't get around it. I drove real slow, but it was fresh and rocks were flying every where. I just want to raise the rear a bit to be able to spin the rear tire. I have a floor jack, I just am still not sure about placement. Or would it be better if I just put the CanAm in neutral and roll it a bit at a time? I apologize if I have posted this in the wrong spot. Thank you for any advice.
Lori
Lori
Just Jack up one wheel at a time.
Make sure that your Jack will handle the Spyder.
A one ton Jack is going to lift it up. .....:thumbup:
It seems nobody ever explains where the jack point is to raise one wheel at a time.
The responses always seem to be use the frame down the middle or jack one wheel at a time.
Where is the jack point to raise one wheel at a time? I want to raise it up and then put a jack stand under.
