Billy,
Thanks for doing this.  I imagine it takes quite a bit of your time.
But I'm a little confused by the remark that I quoted above from your OP.
Please forgive me for being a little dense, but if you are also using the latest Wiredux data, wouldn't both your version and the BRP version be equally up to date?  Or do you get it from Wiredux BEFORE BRP updates their web site with the same Wiredux data?  ...or does BRP use something other than the Wiredux data (and if that is the case, why would Wiredux produce this data?)
Also, when you say
"The difference with my list is it acts just like the list that originally comes with the Can am GPS", does that mean the the BRP updates do NOT look like the one that is in the original Can Am GPS?   If so, how are they different? I downloaded the latest database from the BRP site (D2245000D.gpi) and it seemed to react the same way your database did, under "Spyder Dealers" with the "Y" icon, etc.  (Both data bases were loaded into the Garmin/POI directory and renamed according to which one I wanted to test.)
Thanks in advance for your answsers.  I just downloaded your latest .gpi file and will install it as I do a Garmin map update today.
