IdahoMtnSpyder
Well-known member
Absolutely necessary.Alignment
- I have also read about the benefits of laser alignment. Has anyone bought new and still had this done at time of delivery? Do you think its necessary?
The Spyder handling is unbelievably sensitive to the alignment. I had my 2014 RTS laser aligned at Spyderfest. The next day I complained to Joe and Ann, Squared Away, that it was pulling to the right. Joe insisted the alignment was within the specs they use and suggested I swap the front tires to see if the problem wasn't related to the tires or wheels. This past week I finally had a chance to do that. Now it was pulling to the left. Joe and Ann were in Boise today so I had them check the alignment. Joe said it was off slightly from being dead on but within the limits they use. Had I brought the bike in without having had an alignment done by them, they would have said an adjustment was not needed. But because of the pulling issue he tweaked the alignment to bring it dead on. Guess what? The slight correction, within their normal tolerance range, made a noticeable difference. Very, very, little pulling and more sensitivity to road crowning. I think it corners better also.
Based on my experience today a laser alignment is an absolute must in order to get as near to perfection as possible with steering.
