wyliec
When I replaced the stock battery with the above on a 2008 a few years ago I had to use two L terminals on the positive side.  This was due to the angle of the stock terminal end on the double positive cable.  These leads appear to have some type of shrink wrap combining the two together for about 2". Is this only a shrink wrap that I can remove?  I figure if I can remove it, I can get a little more play in the leads so I don't have to use two L brackets.
