sinkhole
To prevent oil from running onto the pan beneath the oil tank when draining the oil, insert a 2" long section of 1" diameter clear plastic hose (available from Lowes) through the hole in the pan, and over the boss on the bottom of the tank. This will allow passage of the hex extension through the hose so that the plug can be removed. Once the oil has been drained, the hose can be removed and the plug replaced.
