P0175 code and computer reset itself, works for me...
spidergreg
SpyderLovers Sponsor
Last week I was out riding and my 2012 RT started to struggle on acceleration. Then the check engine light came on and the code was P0175 "System too rich Bank 2"... So I searched this website and discovered that there were about 15 different things that could cause this. I was a bit discouraged in that my closest dealer is 3.5 hours away. Limp mode did not occur but the bike would run rough, and then seemed to be ok once at a constant cruising speed. So I got some SeaFoam and added it to the gas and ran the bike for about 20 miles, no change. So I parked the bike in the garage and started to make plans on getting a trailer to haul her to the shop. Two days later, I took her out again and while the check engine light and code still remained, she seemed to have a bit more power, so I ran about another 20 miles or so. Then a few days later, I took her out again and she was again a bit better, but still not right, so I topped off the tank with about 2.5 gallons of pure gasoline (no alcohol) 90 octane. The check engine light was still on but the bike was running much smoother and we rode about 60 miles, we stopped for some sunscreen, and when I started the bike back up after our short shopping experience the check engine light was gone! I have since run two additional tanks of 93 Octane fuel with alcohol and still no problems! I have always put the highest grade gasoline in her that the station has, but I'm guessing I got some bad gas? Or finally the result of the bike not being used? We bought her on July 29th of last year, and she only had 903 miles on her, but we have put nearly 5,000 miles on her since?
Question is, if the error code says system too rich how would using a fuel cleaner like SeaFoam clear it up? Is the computer comparing the difference between bank one and bank two, so if bank one was a bit lean, did the computer think back two was too rich? Either way, there was something wrong because the bike did not perform well. But all seems to be good now!?
Another cause of P0175 is "Injection and fuel supply system".
Just speculating, but a fuel injector can get gummy from sitting with ethanol fuel. Perhaps you had a sluggish injector and the SeaFoam cleaned it out.
Sounds like a bad patch of gas to me... Have had that in my van... The engine actually stops but then everything is fine after a restart.
Easy....
The solution is "Don't let her sit" :roflblack::roflblack: but have to agree with either or both the bad gas and the sluggish injector.
No sitting here
Since we got her, we are riding her! But the previous owner had her three years and only put 903 miles on her... That's Spyder Abuse!!! Heading to SC end of the month...
If you get to Charleston,SC give us a pm or email, maybe we can meet for lunch or something.
