Passenger Arm rests
ranger1369
Due to an injury and MS, my wife has a shoulder droop the makes it uncomfortable to hold on to the hand grips a ride longer than 30 minutes. I have been looking at the Rivco armrests. They have two different styles Dose anybody have either of them and if so can they used to hold on while riding.
Diamond R. Wife approved !
I had Diamond-Rs on my 2010, and Show Chrome on my 2014:
the Diamond-Rs are much easier to install and use. nojoke
It seems that EVERY time I have to fiddle with an adjustment on the new ones: it's a battle trying to find the right tool, to be able to get to them! :gaah:
Arm Rests
I have Corbin and can't recommend them. Delivery time was excessive, installation instructions were inaccurate, and the reinforced screw holes in the arm rests did not match up with the screw locations on the bike.
I have the Rivco and think they are pretty flimsy when mounted. They are solidly built but the mounting I am not happy with. I don't know how the Diamond R's mount but I would lean towards them.
20170323_093253.jpg20160513_113908.jpgI have the show chrome armrests and after I had my Russel Day Long seat done and had my wife's seat raised about 5 inchs so she could see over me I had to do something to raise the armrests. If your handy: I just made a simple framework out of u channel and square channel and painted them and attached to the show chrome mounts. Got new stainless bolts for length needed to attach them and was good to go. As any of these armrest's they are not meant to be used with your bodyweight to get on and off the bike. They are designed to hold the weight of your arms only otherwise you will be breaking plastic. Unfortunately passengers do forget that even after you tell them. NOW, I also do not like the flimsy mounts of these and at some point I'm going to try to find a way to strengthen them up before some panels get broke, but with only plastic panels in that area its definately a head scratcher on how to make a stronger mounting bracket. A future project. safe riding! Sorry none of my pictures will now post in the upright postion and I've tried everything suggested on this sight.
View attachment 145789View attachment 145790I have the show chrome armrests and after I had my Russel Day Long seat done and had my wife's seat raised about 5 inchs so she could see over me I had to do something to raise the armrests. If your handy: I just made a simple framework out of u channel and square channel and painted them and attached to the show chrome mounts. Got new stainless bolts for length needed to attach them and was good to go. As any of these armrest's they are not meant to be used with your bodyweight to get on and off the bike. They are designed to hold the weight of your arms only otherwise you will be breaking plastic. Unfortunately passengers do forget that even after you tell them. NOW, I also do not like the flimsy mounts of these and at some point I'm going to try to find a way to strengthen them up before some panels get broke, but with only plastic panels in that area its definately a head scratcher on how to make a stronger mounting bracket. A future project. safe riding! Sorry none of my pictures will now post in the upright postion and I've tried everything suggested on this sight.
interesting that you had them raise the rear seat, does she feel like she is always in the jet stream with the added height? Just curious.
Joe
I have some corbin passenger armrests available. Like new condition. New $350. Sell for $220 shipped.
We had the Rivco on our 2010 and they were ok. Looked good, but as mentioned, not real strong due to them mounting to plastic. They served the purpose but my wife had to be careful not to put much weight on them. We're also looking at a different option for the 2016. Leaning toward Show Chrome
ISCI makes them, but NOT for the RT yet
them and Big Bike are doing a design for arm rests that swing up not out.
Yes ISCI makes them for the RS and the ST. I just put them on my ST and they are great! Very well made they will probably last longer than the Spyder! They flip up for entry. I like that better than the ones that flip to the side.
Those do look good i wonder how well they fit with the smooth spyder backrest? Looks like the use same bolt locations.
The armrests are adjustable for height. They bolt on under the seat already using existing bolts. Very well designed armrests. Their website is ISCIride.com.
Seeing's the OP was 2017 I would not know!!! But if you look at motorcycle Daves post on arm rest you may be pleased!!!:coffee: Good day
