Henning
Platinum Air Ride bleed feed suspension for Can-Am Spyder RS, WOW! What a difference! As you can see, I have an electrical wheelchair. Together with the lift, it weighs about 60 kg. Plus, I have two Givi bags of 70 liters. With the stock shock I bottom out all the time and cornering at high speed is very wobbly, even with Fox Podium shocks in the front.
With the Platinum Air Ride system the weight almost disappears and when your cornering, it's like you're on rails! It's a learning curve to find the optimal setting, but when you find it, you're in heaven.
Thank you for a great deal and it was very easy to install. I highly recommend Platinum Air Ride bleed feed system. Mike Ferris gives excellent service!
