Bought a Sena blue tooth head set while at Bikes, Blues & BBQ yesterday. Thought I would give a short review for those that might be interested.
I didn't install it myself ( had the guys in the booth do it while we walked around), but it looks fairly simple. Paired up with my iphone 3gs with no problem.
Took a couple of phone calls from Gary while we were riding around. The phone quality seemed good ( at least incoming, Gary can answer for how it sounded from his end). Turned on voice control of the phone and it worked fine, 1 false call out of 4.
The music controls are actually good. FF/RW, pause, play all worked fine, even in Pandora. Can do all that from the dial on the side of the headset or with voice control. That's functionality I don't have with the controls on the spyder. Not sure why, but when plugged into the spyder sound system it will only do FF/RW, pause, within ipod, in fact it turns off Pandora if I hit any control except volume.
The sound quality isn't what I would call great, but it's not bad. Just doesn't seem to have any bass or depth to the music. That said I can hear details in the music better than with the spyder sound system.
While it doesn't have a spare battery, if you have a 12v power outlet handy you can use it while plugged in to charge at the same time. 8 - 12 hour run time.
Haven't had a chance to test the blue tooth intercom system. Says it will work with any other blue tooth headset. When I get a chance I'll post the results of that.
