Is there a trick to getting the Right Rear Axle Cap for a 2022 Spyder RT on properly?
Jaywalker
I purchased a used 2022 Spyder RT Sea-to-Sky and noticed afterwards that it was missing the Rear Axle Caps which was on my previous F3 Limited. The left cap went on with no issues, but when putting on the right cap (side with nut and pin), it doesn't want to go on all the way. I can only get it to go in about half way. Also notice it was missing the pin which prevents the nut from backing up? Is there a trick to getting the right cap cover to go on or do I need to lower the muffler and whack it with force? I wasn't able to find any videos on YouTube which had similar issues. Yes, both caps appear to be the same length. Did I get two left caps?
