Rear suspension pressure.
If you look under the seat by the valve there should be a sticker telling you the pressures if this is the basic RT. If not it's in your Manuel
:agree: Do a little bit of homework... :thumbup:
My guess for two-up... you'd be at the maximum settings (90 psi?)
Before I put the ACS system into my 2010; I'd run about 65 psi for the two of us... (200 & 165 pounds... But DON'T tell her that I mentioned that! :D)
