Yep, Tele, we seriously don't need
yet another thread asking this question, and it
ALWAYS pays to do a search first before starting a new thread, only please do check the date on the first post in the thread and at least the last few posts in the thread, then make a judgement call on if the posters in that thread are likely to answer any questions! And a little thread archeology is OK, if it adds to the knowledge base &/or shared experiences, but there's not much point in dragging up an older thread if none of the posters in it have been around for anything over a year or so.
Apart from that,
firstly, you really should either include the year and model of your Spyder in the text of every one of your posts that's asking Spyder type questions, or maybe you could just follow the instructions in this thread so that those details are on every post you make:
https://www.spyderlovers.com/forums...l-Add-your-Spyder-Year-model-to-your-Sig-Line!
Secondly, it really doesn't matter if your Spyder's a base RT; an RT-S; an RT Ltd; or any other Spyder that's been sold since 2013 (pre-2013 Spyders ran 14" rims so they run different sizes of tires!
 ) they will ALL run the same size tires and there's only a few sizes that will actually fit - but effectively, ANY reasonable quality car tire in any of those sizes that fit are going to be good! :thumbup:
And
Thirdly, all you need to do is put '
Tires' into the Search field, or maybe '
Tires' & '
recommendation' in there; click on the '
Search Titles Only' box in the drop-down list; submit the search; and then use the titles to help you pick which threads to read first.
