You will REALLY be impressed with the amount of light you will have with the LED's ..... I've done a few swaps and the only caution I would offer is you will need at least a 6in. extension to reach some of the i0mm bolts on the lamp units. and be very careful not to lose any bolts ....I usually put some paper tape into the socket so it's tighter .......good luck .... Mike :thumbup:2017 RT Limited. The stock headlight bulbs are just to weak and would like to replace with LED. Appears they are standard automotive HB3 9005 bulbs. Has anyone replaced just the bulbs? Anything to be aware of with this replacement?
I did both Head and Fog lights from TricLED, worth every penny, I've rode cycles for 40+ years and never had better light at night.
The OEM wiring harness and circuitry is designed for the halogen bulbs. LED kits supplied by Lamonster and TricLED have a) finned bulb holder to dissipate heat and b) an inline black box with circuitry for the LED 'bulbs'.2017 RT Limited. The stock headlight bulbs are just to weak and would like to replace with LED. Appears they are standard automotive HB3 9005 bulbs. Has anyone replaced just the bulbs? Anything to be aware of with this replacement?
, #1.- there is LESS power draw using LED bulbs, so the OEM wiring harness has LESS of a load to carry ........... #2.- I don't know what LED KIT you are referring to - the kits don't have any extra wiring both TricLED & LaMonster are selling you LED BULB re-placements. The difference between the two Vendors kits are LaMonsters has an EXTERNAL Ballast....... I did have some concerns about HEAT dissipation so I drilled some holes in the covers .........that was quite awhile ago and I haven't had any water issues ....... Mike :thumbup:The OEM wiring harness and circuitry is designed for the halogen bulbs. LED kits supplied by Lamonster and TricLED have a) finned bulb holder to dissipate heat and b) an inline black box with circuitry for the LED 'bulbs'.
If you just replace the halogen bulbs with an equivalent LED bulb, you may not have the heat dissipation capability or LED circuitry needed for the bulb to work properly in the OEM harness, even if it physically fits the connector.
There has to be a reason kits cost so much more than just a bare LED replacement bulb....nojoke
A friend replaced the halogens on his 2016 Ltd with LEDs from Tricled and they give a lot brighter light. As Mike said, the top center 10mm headed bolts need a socket and extension. SpyderAnn recommends to to tape the head of the bolt to the socket with a small piece of painter's tape. When you have tightened the bolt and remove the socket the tape will remain on the socket. Works like a charm.
Do be aware if you change your headlights to LEDs you will have white headlights and yellowish foglights. Changing those foglights, friend also changed his to Tricleds, is a frunk removal as it is virtually impossible to change the left light because of interference from the air intake.
Just did the Tricled headlight and fog replacements.FYI on the headlights-on my 18 rtlt there are 3 tabs at the back of the bulb mount that coincide with the under tabs that lock the bulb in place BUT these stick straight up.On my install these tabs stuck up into the cooling fins of the bulb and made it impossible to turn bulb to seat it.Once the problem was observed it was easy enough to bend the tabs out of the way and bulb turned easily to seated position.
