spyder30517
Just wanted to let those that have the sport rack, that you can buy the material at Michaels Arts and Crafts or probably any craft store.
I had my sport rack repainted so they had to be removed - just soak in laquer thinner and use a plastic scraper to remove the old pads and save for template.
It is make-your-own mouse pad material with adhesive already attached
9"x12" sheet is $.99 - larger size/colors available as well
Plenty of material to cut out your own and then some, as I am sure somebody will find other uses for it :yes:
