Run Flat Tires
Run-flats (I think!) need to have a wheel with a bead that is specifically designed for them; don't they? :dontknow:
I know vehicles like our past BMW's that came with run flats could have non run flats installed on them with no problem. I thought it also worked the other way but I won't bet the farm on it. I believe some Goldwing owners that went to the dark side used run flats on their stock rims. I think the problem for us is that there just aren't any sizes available.
Gary
Thanks! :thumbup: I wasn't sure if a special rim was necessary; I just thought that I had read something about it once... :dontknow:
rft's use regular wheels it's pax tires that need special wheel. i would never put rft's on my bike and currently won't own a car with
them. rft's are more expensive, harder ride, stiffer sidewall which causes more bends, cracks & bubbles in tire & wheel.
Had RFs on my BMW Z4 and took them off. They tramline terribly and produce a harsh ride. They also tend to fail by bubbling or balloon on the sidewalls. I just can't imagine how badly a Spyder would handle with them. A better idea is to carry a tire repair kit including plugs, slime, and an inflator.
I ran a RF on the rear of my Goldwing for about 75,000 miles and had one on it when I sold it. Did not need a special rim, TPMS nor did I catch on fire. It is a very sensitive subject in the Goldwing world.
