Seat won't release!!!!
Lew L
Well-known member
After installing the new seat strut my seat won't release:mad:. The key depresses and turns fine,there is even a bit of play in the seat ( up and down about 1/4" ). I've push and pulled and even said "cr@p"!!!!!
Can I get to the cable manually somewear ?? Under the dash maybe???
I'll say the new strut is much stronger than the OEM and was easy to put in ----BUT-----:banghead::banghead:
Kaos
The seat release can ba accessed from underneath the "nose" on the right-hand side of the seat.
Here's a picture of what things look like:
This one has had an emergency release cable attached to it...
If you follow it back to the latch: it kind of shows you how the proper screwdriver might be used, to make it move.
But since you added the extra-strength strut: that is probably putting extra loading on the latch.
Try pushing rearward on the seat, and operating the latch... :thumbup:
I just replaced the seat shock with the 40# one also. I noticed that my seat does not pop up all the way, that post gets caught on the edge of the hole and only moves a little.
The OP should try pushing down on the seat, turn the key and hold it while he moves the seat around left/right/back. I got mine to release and I will try to center the post in the hole to solve my issue. YMMV but good luck.
Thanks Bob
Your picture showes me all I'll need. It doesn't move when I turn the key so I think the seat "bolt" is holding it from releasing. I'll keep at it but your picture really helped.
Kaos
Fixed and better than new!!
Thanks again Bob.:D THe seat now released ( with the slight adjustement to the "latching bolt") and pops right up upon turning the key. It even turns easier!! I also installed a cable release is just like the one I put on the Frunk and is only there just in case.
The new gas strut is a great mod, Easy to install and simplifies refueling.
Thanks again ----- Kaos
I did away with all the seat drama/issues by tie strapping my seat latch to the full open position, solved that not opening problem and having to use the key everytime...took 2 minutes to do. As far as the seat not staying up after you add a drivers backrest or whatever I took my shock off, made a wooden dowel prop rod the length I needed, drilled a hole in the end where the original strut attached to the seat, put a clip on it and fastened it to the factory seat strut pin. Took 5 min and all problems solved. NOW before everyone goes bat s#$t looney that someone could get at my gas tank, let me ask.....when was the last time you heard about anyone screwing with a persons gas or tank? I'm a gambler, not too worried. safe riding!
I did away with all the seat drama/issues by tie strapping my seat latch to the full open position, solved that not opening problem and having to use the key everytime...took 2 minutes to do. not too worried. safe riding!
The simple solutions are sometimes the best ! Thanks for the idea :D
Photos?
Guess I don't know what you want a photo of????? In post #2 there is a photo of a cable release, mine is almost identical. The gas strut replacement looks just like the stock strut but is more powerful and easily lifts the seat upon turning the key.
Kaos
