Hi everybody,
I'm trying to add the rear red side reflectors with the LED upgrade. I have the light mounted but the instructions that came with the kit says to route the wiring "out the bottom" of the saddlebag. The only way I see to do that is to drill a hole in the back Shell of the saddlebag, am I being stupid and not seeing something? It also says to tap into a 5 wire connector behind the rear light but that connector is damn near impossible to get to.
Any hints from someone that has done this? I also plan on changing out the front fender side reflectors with LED.
Thanks for any answers.
Sean
Sean
