So if you're like me and have limited mobility in your knee/hip/ankle and find the height of the Can Am Spyder brake pedal just too high, then the Brake Rod Kit is just what the Doctor ordered. I knew within the first 50 miles of riding my Spyder home from the dealer that the brake pedal was going to cause me severe pain on long rides, so I immediately started searching for a solution.
The first item I found was the Lamonster Floor Board Risers (awesome product) but at 6 foot tall and having knee/hip issues, I got ride ending pain in my quadricep, and that kept my rides under 3 hours or I needed to take a 90 minute rest stop.
So once again the quest for a solution was on, and about 10 days ago I got an email alert about new product from Slingmods - it was the
Brake Rod Kit for the Can-Am Spyder RT (2020+) I mulled it over for a day or 2 before I pulled the trigger and had it shipped.
Overall, it is a pretty stout unit, being thicker and heavier than the stock piece. Installation is pretty straight forward, you will need a 5 mm allen key/wrench, 10mm wrench, and a 19 mm wrench (for the jam nut on the new brake rod). I have now completely removed the Lamonster Floor Board Risers (wicked awesome product BTW) and have a nice easy transition between the floorboard and the brake pedal.
ONE THING everybody needs to check is the rear bolt on the clevis (at the brake light switch) - my nut was missing :yikes: and that could have ended badly for me and my wife. The only thing holding the bolt in was the spring on the brake light switch. :shocked:.
The install took me longer than it should have, but I had the Risers to remove and I had to dig through hundreds of nuts to replace the missing one (check your nuts people). The install would have also gone a lot faster if I had at least one ramp to get the trike a little higher, but if my 6 foot 261 pound broken down body can do it, so can you.
I took my time finding just the right height for me, and as of right now, the bottom of the brake pedal sits at just 2 inches and has plenty of throw. I was standing hard on the brakes from 60-65 mph and the trike stopped hard and fast. So here's the video and picture (maybe picture)
https://www.youtube.com/watch?v=fSF_uyJFru0&t=6s&ab_channel=AsmallSLICEofAmerica
