ridercoach
Has anyone mounted the aluminum Can-am Sport Rack on the rear of a Spyder RS? Would it be sturdy enough to hold a top trunk? Thank's
& how happy are you with it? Any concerns or hassles? Thx![]()
That's a Givi Monolock base I had bolted on. I now have a Monokey base bolted on for the Givi Monokey Maxia top box. There are angle frame pieces between the Givi base & the sportrack. It is the angle frame pieces that are boled onto the sportrack & the Givi base then bolts onto the angle pieces. At least that's how I did it.
Hi ridercoach,
Re: Has anyone mounted the aluminum Can-am Sport Rack on the rear of a Spyder RS? Would it be sturdy enough to hold a top trunk?
I posted most of these photos in another thread; this is a home-built luggage rack:
And here is how I reinforced the back side of the Sport Rack top plate:
I used two pieces of 2" x 1/8" flat stock, cut to fit.
I do not know if these will work or not. But they do spread the stresses out over a larger area and hopefully that will be sufficient.
If you have any questions, just drop me a line; or ask to look at it at SITR. That is if it makes it that far, :thumbup:
Jerry Baumchen
Looking @ pics it has same release button as saddlebag? Handy 3rd suitcase or cooler & looks color matched? 1thing BRP will not offer or key match. Looks great on yours fyi
