A week ago yesterday I made an appointment to have my rear tire change and to install a new belt at a dealer 250 miles away from where I live. At the time I made the appointment I was in OKC attending to some business there and the dealership in Missouri was on my way back home to SE Missouri. I arrived at the dealership at the designated time. My partner and I left on his Goldwing to go run some errands while they were changing the tire and the belt (I had foolishly followed a friend down a newly chip and seal road resulting in numerous tar encrusted rocks, two of the rocks were close to the edge and one of them had actually gone through the rubber and put a hole about 1/8 of an inch from the edge). When we got back to the dealership from running our errands, they called me on the phone and told me that I had an additional issue that they needed to discuss with me (the service man did not know I was actually in the dealership building). I walked to the service counter and they explained that my sprocket was bad and was needing to be replaced. The service mechanic went on to say that it was BAD (emphasis on the bad). He said it was so bad that he did not want me to walk out of the dealership without knowing just how bad it was. I asked a ton of questions, like how did this happen, what exactly was wrong with my sprocket, why did this happen and how many others have you seen on a RTL. He told me that he had changed out about 20 in his time as being a certified Can Am mechanic (no length of amount of time he had been certified). I was told that one of the reasons was due to operator driving habits and they asked if I "hotroded" my spyder. I told them no that 99.9% of my riding was done on paved roads and that I only go 5 above posted speed limits. I asked if they felt like the sprocket would survive the 250 mile trip back to my home. They remarked they had no way of knowing how long it would last. They asked me twice if I wanted them to change it out; I asked if they had the sprocket in stock, they said no. So that would mean that I would have to leave it there, wait for the part from Canada, wait for them to install it and then make a trip back to pick it up. Thankfully it would be covered under warranty.
Since I had not experienced any issues with my spyder, I was shocked and a little bewildered. I chose to attempt to get it back to my home in SE Missouri and then call a dealer closer to my home and order the part through them and then attempt to get it to that dealership. I rode my Spyder the 250 miles home with no issues, however I was clearly scared that the rear wheel would stop at any moment. I drove under the speed limit, trying to lessen the pressure on the sprocket. The next day I called the dealership closest to me and ordered the part. They opened a repair ticket and gave me a date to bring it in for installation.
Yesterday I rode the 86 miles to the nearest dealership where I had ordered the part so they could install the sprocket. My partner and I waited in the lounge at the dealership for them to do it. About an hour after we got there the service mechanic came into the lounge area carrying my sprocket in his hand. Apparently the other mechanic did not even take off the sprocket and do a visual inspection. In his words he said, "I spun the wheel and it made a pop, pop, pop sound". He told me that that indicated the sprocket was in bad shape and was failing. Below is a picture of my "failing" sprocket.
I was in total disbelief, as was the service mechanic. There was nothing wrong with my sprocket. No wear was detected. Yes, there was red dust on the outside and I questioned the mechanic regarding this red dust. He said the red dust is a residue of the Loctite and not an indication of a failing sprocket. The service manager came into the lounge and also confirmed that my sprocket was fine. Since they had opened a ticket on a "supposedly" failing sprocket, they were going to install the new one and send the original one (picture above) to BRP with the explanation of why they had installed the new sprocket along with the other dealers name and address.
I learned a valuable lesson from this. Never take the mechanics word for what they are telling you is wrong. Insist on seeing the "damaged or failing" part.
When I had been told by the first mechanic that my sprocket was BAD the first thing I did when I got home was to log into this board and researched threads regarding the sprockets. So my questions to others here, are you changing out completely good sprockets by diagnosing a failing sprocket by the red dust or are you doing a visual inspection? As you can see, my sprocket has the red dust, but I have no wear. Also, I might add that I have 39,000 miles on this sprocket (it's a 2016 RTL).
