Steering Issues-SM or SE-5 or both?
SpyderCrazy
I was reading some of the threads about those that are having issues with the steering. I was wondering if those that have steering issues have an SM or SE-5. Thanks!
:dontknow:
My sm Steering issues
I have PE #610 with 20,000 miles on it and the only serious problem I have had with it is with the power steering being intermittent. Being intermittent, it would require a lot of force to make it move and then all of a sudden the power steering would kick in an you would have oversteer. This is not a good feeling. On the open highway you can almost make yourself believe it is working correctly. In traffic it is a nightmare. On curves it is a workout AND a nightmare.
First they changed the entire power steering unit- no help.
Next they tightened a ground wire under the seat. Fixed it for 12,000 miles
Last they changed the gear position sensor?? It is working well now for a few hundred miles.
I doubt that there is any difference between a SM and SE except for that gear position sensor maybe. Bigger brains then mind will have to address whether that is the difference.
I understand that the steering mechanism is the same in both the SM and the SE-5. I was wondering if maybe it could be a defective part that was used either in the PE Models or before they started producing the SE-5's.
I think there are more SM's on the road right now but my guess is percentage wise it would be about the same. :dontknow:
