BumbleBee
RT-S PE#0174
Here are the first new RT products from ESI to hit the street.
I just finished installing the Triple PLay & Shorteez Antenna.
Installation of the Triple Play was fairly simple even for a novice like me. Removing the rear panel involves disconnecting the saddle bag shock absorbers and a small inside screw that is rather difficult to access.
See installation photos;
http://www.spyderlovers.com/forums/album.php?albumid=653
The end result is surprisingly bright tail lights, brake lights, and reverse lights. The conversion kit was preset to the setting that makes the brake lights flash 4 times then remain full on when braking (see video below). That's where I left it, as that's where I wanted it. The whole process took about 1 hour.
(to the right of the sound, you see 360p. Change it to 480p)
I recommend these lights to all spyder owners. They greatly enhance visibility and safety. The back-up lights improve visibility to the rear. I really Love the lights :thumbup:
The Shorteez Antenna features a Power Coil that allows for crystal clear reception without all the length in the air.
This unit screws right in place of the stock antenna, I have installed the matt black. The conversion took about 2 minutes.
The antenna is about 1/2 the size of the stock antenna. :thumbup:
Thank-you very much to Magic Man and ESI for developing such wonderful products.
