BajaRon
Well-known member
Hi guys,
Im in the midst of installing the BaJa Ron bar on my 2019 RT limited. Using ramps, straps and jack supports so no issues getting up high enough. However, i see no channel stiffener bolts and spacers in the channel. It does have the holes for them. The paint where they go is not disturbed at all on either side of the channel, meaning no bolts have been in there. Whats the likely hood never installed by BRP from factory? Any one heard of this before?
I went to the local Can Am dealer and they could not locate the correct parts diagram for the channel with the stiffener bolts and spacer, so I could not order them.
Any body have part numbers? I " think " they are M6 1.0 tpi x 50 mm long. Spacer would be 35 wide to fit in the channel.
If i cant source them i'll end up getting the parts from McMaster Carr or Grainger or Threads of the South, preferably in stainless steel
Thanks Milburn
I am surprised they could not find these stiffener bolts. However, I am puzzled by the dimension given. They should be longer. I wonder if this is an error in the parts fiche.
