The side panel with the fake screws
pitzerwm
While replacing the headlights, I realized that I had cracked one of the "studs" that go into the grommets on the side panel that seem to have 2 fake chrome bolts. It was the one closer to the back of the bike. I decided to use epoxy on it. While messing with it, I discovered that the screws are not fake, but rather a security "screw". I had a set of the HF security sets, so I found what worked. Its a tork, the smaller one with a pin in the middle.
attachment.php
Yes, and your not suppose to mess with them because the prongs are aligned to go into the lower panel. If you change the alignment of the pin you may have to play with the angel of the pin to get the Tupperware to line back up.
Sent from my SCH-I545 using Tapatalk
Bill they are called tamper resistant torx. To put that panel in it is usually easiest to put the forward stud in and then bow the panel to insert the rear stud. Be careful or you will push the grommet through.
I did see that, actually there is some plastic that holds them at the proper angle.
You are right, it seems to work best that way. I cracked it I think the last time I put it on.
You're looking for part#705003842, Knob, $4.99. The bolt is part#250000459, Torx screw, K50-X16, $3.49 in pack of 4.
