Things you want BRP to make standard on Spyders.
kbwitt
1 bette sway bar
2 blue tooth stero with USB port to play my music
3 usb port for charging phones or gps
4 speed ometer to be accurate
5 clock that does not keep gaing time. ( $ 5. 00 watches are accurate )
6 fuel door on seat
Kenn
As nice as that all sounds I would not
hold your breath waiting for that to
happen
1 bette sway bar
6 fuel door on seat
Kenn
A D.E.S.S. System that works! Each and every time. This would make me more than happy. :thumbup:
1 bette sway bar
6 fuel door on seat
Kenn
How about a spell checker??
Cruzr Joe
(Back to Business...)
Yeah... I'd like to see the rear valve stem repositioned.
Having the GPS built into a larger center screen would be cool...
The clock and thermometer are so small that I can't see them; they're not an issue for me. :D
How about this:
The top trunk and saddlebags are not well-designed.
Make the saddlebags a bit wider, and about two inches longer (front to rear)
The top trunk should also be extended rearward by the same amount...
...or at least moved rearward, so that some more rider/passenger space can be opened-up for use. :thumbup:
3rd brake light should be standard
The third brake light should be standard.
A little higher ground clearance would be nice.
Those are my two cents worth! ;)
