Hey D. Throttle Body Replacement was typically performed based on code P1614. And once you had the latest throttle body and software for that machine, any further P1614 codes were treated by throttle body cleaning. Sometimes the throttle body was replaced based on your two codes when the warranty was still in affect, but typically wasn't successful.
Your two codes simply indicate that the throttle position that you are asking for from your right wrist, does not agree with the actual throttle position that you are getting - coming from the Throttle Position Sensor - attached to the rear end of the throttle body butterfly valve shaft. It fails its little comparison test. This is a separate component and can be replaced separately from the throttle body. So…10 months ago….did they replace your sensor when they replaced your throttle body, or reuse the old one? Was that work done because of code P1614? If the sensor was the problem all along, then just resetting the sensor in BUDS is only a temporary bandaid. A new sensor needs installed and initialized to the new throttle body.
I don’t think that I’ve ever heard of the twist grip sensor on the handlebar failing.
So, I’d be thinking about a cleaning or a throttle position sensor replacement long before I did another throttle body replacement.
Service Bulletin on P1614:
https://drive.google.com/file/d/1dsG-jvXSxYxfSYMzFsVzzrhvXczIWQJQ/view?usp=sharing
As an aside - some engine management systems utilize the signal from the Manifold Absolute Pressure sensor - in addition to its normal job - as a reasonableness check on the throttle position sensor. Manifold absolute pressure is a general indicator of throttle position. I’ve never been able to track down if the Spyder uses this. But, I bring that up because that manifold pressure sensor is connected to the throttle bodies by rubber vacuum hoses. They had to disturb them in order to replace your throttle body unit. They should have given you new hoses. If they reused the old ones, the hoses could be damaged, thus impacting the output of the sensor.
Unfortunately, from reading back on old posts, after losing a lot of hair over this, a lot of folks solved this problem by just trading up. Good Luck.
