Torque wrench?
Revrent
I am (what I consider) a typical back yard mechanic. I have a tool box full of tools and all three sizes of the Harbor Freight torque wrenches, which over the years have been close enough for the places I needed to use them. However I do not want to use them on my wifes Spyder. That is an insignificant point in the fact that none of them go high enough to use on the rear wheel of a spyder anyway.
Looking for recommendations for a torque wrench that can be used for the higher torques (and lower torques), Ie rear wheel of a spyder (higher torques).
Thanks in advance
John
I would try snap on. My father was a mechanic and he bought snap on tools. He used to say buy the best tools you can afford. I would not want to be using cheap sockets or wrenches on a higher torque specified nut. !st is safety I have seen the cheap sockets break and second is accuracy of the wrench.
You can also get a torque multiplier. This will work on any ratchet or breaker bar of the same drive (1/2" is recommended). It converts these tools into an accurate torque wrench.
There are several quality brands of torque wrenches. Snap On is one.
You mention wanting a torque wrench for high values and lower values. I suspect the wrench capable of the axle torque will be above the range for drain plugs or similar smaller fasteners. So sadly, I suggest buying two.
You might consider though, having you Harbor Freight torque wrenches calibrated, if possible.
This works GREAT!
https://youtu.be/XaqBA-xSGbc?t=228
That essentially all torque is. Force applied to an arm.
Downside of what you linked will be how accurate or calibrated is the $5 scale being used.
Years ago, at a place I worked, bolted to the building beam was setup that had square drive for the wrench, and raised calibrated dead weights.
Rather than save money cheaping out, buy a good wrench instead of buying parts.
there are several sites on youtube that put the test to snap-on and HF. In ALL of the vids that I have watched. The HF torque wrenches out performed the snap-on. Look for yourself.
There are better Harbor freight tools now a days.
I use a Lowes 1/2 drive torque wrench (kobalt) on wheels and higher torgue values like the Spyder axle nut.
If you are really going to use the torque wrenches like they were meant to be used, you would need a 1/4 inch, a half inch, and a 3/4 inch. I have never owned a Harbor Freight torque wrench, so I will not comment on the quality. If you take care of the torque wrenches properly, even the less expensive ones should be OK for a home shop. The main thing is to back off of the torque setting so there is no pressure left on the wrench when you store it. They should be stored in their case and never just thrown in a tool box drawer with the other tools.
If you are concerned about the accuracy of the torque wrench you already have, there are ways of testing them.
https://www.youtube.com/watch?v=kGbCzm8lrKE
Snap-On. 1/2 inch drive range is 50 to 250 foot pounds. I have had mine for twenty some years. Excellent tool.
Luggage scales (especially digital, which is the only way I'd go) are very accurate. Just a tad over on luggage, and you'll pay BIG TIME these days. And everyone is trying to get as close to the max allowed as possible.
I've tested my luggage scale against my digital postal scales (which are always right on or, at most, 1/10 ounce off with the USPS scales). And my luggage scale agrees with both of my postage scales. I think being within 1/10 ounce is good enough for a torque wrench calibration.
Torque wrenches are usually not nearly as accurate at the lower and upper 10% of their range. To get the most accurate reading from a torque wrench, it's best to stay within that 80% middle range. So, if you have a torque wrench rated at 50 - 250 lb. ft. You want to keep it between 55 and 225 lb. ft. if you can.
The HF tool would be good enough for anything I would work on,or you could go with the old 3/4's past striped method when all else fails!!:roflblack: Has worked for me for 63 years and never lost a thing in the woods!:cheers: Keep it simple
Well then, with a Snap On 1/4” drive 30-200 inlb click type torque wrench, a Snap On 150-1000 inlb click type torque wrench, a Snap On 5-75 ftlb click type flex head torque wrench, a 30-200 ftlb Snap On click type torque wrench, a 0-600 inlb Consolidated Devices dial gage torque wrench, and I still have my first torque wrench, a Craftsman 0-600 inlb bending beam torque wrench, seems I fulfill your 80% criteria.
As for the luggage scale testing, truly very glad it works for you.
Ironically, on older aircraft, often the torque holding the propeller on the engine was to have a steel bar through the prop nut, and a person hung from the steel bar while gripping the bar at a certain length, often around 4 feet out from center.
A torque wrench is considered in spec if between +- 10 % the one I use the most is 275 inch pounds and is kept right at that spec.
I use torque wrenches every day, Ours are checked every 6 months.
T.P.
Harbor Freight also has a new line of Professional grade tools called Icon. I did watch a lot of videos with tool tests and the Harbor Freight stuff comes out pretty good now.
