Trailer adapter
Danz28
I know there is an older post of this from a few years ago. But I am going to look at a trailer tomorrow new in box that has a 4 wire flat connection. I all ready have the 2012 wire harness on my spyder and was wondering if any one has made a simple adapter yet fro. The round to flat 4 pin. Wiring in not my strong point and if I'm left to my own devices of splicing things there is a good chance I'll set my bike on fire. Would I be better off taking out stock wiring and adding one of the harnesses from big bike parts?
there is a 9 pin round schematic on here someplace. Once you have that, the pieces should fall into place.
I have a square 4, which works with "nothing else" also. I let my buddy with a circuit tester and a Hopkins adapter
turn my trailer 5 pin rd(aluma) into a 4 square in about 10 minutes.
also, for the tronically challenged, like me, any reputable trailer dealer will be able to do this in a flash for little cash.
The 2012 is a 9 round pin device
Ya you might be better off getting the new module with the 4pin square & harness, I believe there were some updates so they dont burn out as ez :dontknow:
Ask you tech & or hopefully some one here can confirm :coffee:
The square to flat is way easy to DIY
9 pin to 4 pin
Someone used to make the changeover harness, not sure who. Sometimes the harness comes up for sale here on SL. It's about 10 inches long and usually about $25. Good luck.
