Transmission light
Lawdog29733
:pray: Help!!!!
changed the oil a few days ago and now my transmission light keeps coming on. Can someone tell me what going on? HELP!!!!
I have an RT but I would check your oil level. Low oil can make the light come on.
What he said.
Did you run the engine, then check again? I had to do that a couple times to get the oil level right.
The other thing that tightened my sphincter, was after the oil change, it wouldn't go into reverse for a couple minutes. I guess the oil just hadn't circulated fully yet...
Let us know about the oil level and if adding a bit more fixes the issue. The SE5 can be very touchy based on the oil level at times, and for long trips I usually take an extra quart with me for just in case something happens.
