tofriendscreek
Is there a way to adjust something/somewhere which would keep the trunk/top case open on a 22 F3 Limited?
"started with the addition of the rack"
This was the case for me also. I need to look for a fix. I would think there would be a gas strut that could be added to solve this issue?
F3. My 21 doesn't stay up either. They have a gas strut. But I suppose the luggage rack on mine is part of the problem. I cut a piece of wood to stick in the hinge to keep it up.Well my 2017 F3 Limited doesn't have a strut. When I lift my trunk lid it snaps in place and won't fall until you push the orange release lever. Are we talking about F3's or RT's here.:dontknow::dontknow::dontknow:
Slingmods has a heavier duty replacement. Here's the video on replacing. I did the trick above of putting a heavy duty spring on teh strut to support it. Not as good, but waaaaay cheaper.
That video does not show the orientation of the mounting post for the 2020 RTLimited trunk.It is not that easy...
The hardest part of replacing the strut for me was removing the spring clip off the bottom post mount, otherwise it was straight forward, quick and relatively easy. Best of all the new strut works way better than the OEM ever did.
