Tupperware attachments
Joeb0716
On my RT somehow the attaching point on the external cover over the oil dipstick is 'breaking' loose from the panel which is the bike skin...
Is there a way to repair the attaching fitting? A rider I met a few weeks age said to use (black ABS cement) like plumbers use. I did an application in layers, letting it dry well before the next application. It lasted about 2 cover removals...
Is there a mod of any kind to replace the plastic standoff & pin assembly? I thought I might machine one on my lathe out of a bolt that would pass thru the Tupperware to the outside.:helpsmilie:
Or does anyone have a better idea?
Have a great day,
Joe B.:spyder:
I'd approach my dealer to see if I could get the cover replaced under warranty. If it was not abused, it may have been cracked from the factory. It is not an item that is readily damaged in normal use.
