Turn Signal - when does the self cancelling signal cancel?
Pg 21 of your operator's guide.
The manual says that when the motor is running, the turn signal will automatically turn off after 30 seconds. Very misleading! After a ‘shallow’ turn, you must turn if off yourself.....same thing for a lane change. IT WILL NOT automatically turn off after 30 seconds, or at least mine won’t.
:agree: ..... It is what it is .... poorly made or poorly designed .... lots and lots of complaints about them ..... Mike :thumbup:
So
:yes::yes::clap::clap::2thumbs:THANKS for using Blinkers at all:firstplace::doorag:
People need to mind their own businesses, not where I'm going. Therefore, I do Not use turn signals.
Cheers!
My '14 self-cancelling seems to work well on 90 degree turns well enough, but anything else - not so much. And yes, I've run into the same issue when trying to manually turn them off - turn on the opposite signal, then maybe off.
After this thread arose I was on a long stretch of U.S. 29 in VA and pressed my turn signal button for a right turn or lane change and just let it blink until it self-cancelled and it did so in about 30 seconds.
Interesting. I’ve never left mine go quite that long. Guess I’m gonna have yo try it!
