It's when you introduce
significantly different adhesion limits & performance characteristics from side to side (ie, running different types/treads
across an axle, front
or rear) that things become quite unpredictable & so can potentially produce
SERIOUSLY bum puckering moments! :yikes:
With matching tire types/tread
across an axle, the 'side to side' variations are
there, but they aren't usually massive
&/or mutually antagonistic, and most tires are designed & engineered to be generally predictable as well as usually giving the operator some warning before the tires reach their limits & let go! And even if/when one of those ends 'let's go' & hangs the tail or even spins, if your operator is reasonably competent, the situation is usually (eventually
) recoverable, if you don't hit something first! :lecturef_smilie:
However, when you run different tire types/tread on either
side of the vehicle, that basically progressive & relatively predictable nature of 'over-steer vs under-steer' that is something most people learn to manage reasonably well from the moment they start learning to drive just disappears..... so
instead of having correctable & in some respects, even 'controllable' over-steer or under-steer 'incipient spin' situations when one end or the other steps out (consider those 'drift cars' you see, or you hanging the tail juuust a little on slippery corners, etc) the driver/ryder can
SUDDENLY end up in what is an effectively uncontrollable situation, simply because as the vehicle loses control &
snaps into a spin &/or a roll and ends up wildly gyrating its way off or down the road, while & where the continually changing grip from side to side doesn't (& can't!) respond readily to
any of the control inputs the Nanny
OR the driver/ryder is likely to capable of providing in a suitably effective timeframe! :banghead:
Even the really capable & very effective VSS that our Spyder/Rykers run simply won't let the Computer OR the Ryder provide timely control input to either
side of the machine's three wheels/control surfaces, the tires (braking right front &/or rear, vs braking left front &/or rear, OR vs braking right front only &/or braking left front only - or was that dropping power to the rear, or the right side rear vs the left side rear?!? :gaah: ) and altho the VSS
can brake one or more control surface (tire) it can't control the sides so much as it controls the
corners or the
ends of the machine, and with the handlebars &/or the throttle/brakes, the Ryder too
CAN provide control input to one
END or the
OTHER! :thumbup:
So if you've got reasonably matching grip & handling characteristics
across the axles
at each end, the Computer can predictably & in a timely manner control those ends, even working to reduce the likelihood of flipping/rolling, just as you the operator can learn/develop the skills to minimise those 'let go on one end' situations & maybe even develop some skill at controlling the lesser 'let go on one end' situations in time to save your machine from spinning or rolling. Heck, most of us Spyder/Ryker ryders even enjoy 'hanging the tail' a little every now & then, but I don't know of any computer on a road based vehicle or of
anyone driving/riding any vehicle who enjoys losing control over
just the right
side of their vehicle or
just the left
side of their vehicle - especially if it ends up flipping, rolling, &/or spinning, and so gyrating its way down the road with uncontrollable sides and ends!! That's called an 'unrecoverable spin/roll' vs the 'over-steer or under-steer' induced spins that are generally considered to be avoidable & potentially recoverable (
if you don't lose control of one side & roll, &/or hit anything first!!
) Make sense?? :dontknow:
