What diameter are the Spyder RT 2024 Handlebars?
Burtman
Does anyone know the diameter of the handlebar on the 2024 RT. Looking at the Quad Lock mount for my iPhone.
Don’t know the diameter but I installed the Quadlock on my 2024 Spyder RTL a couple of weeks ago. They give you different rubber insert thickness pieces. I used the thinnest one. Worked fine. Just be careful with getting the lower portion around the handlebar with the cable there. Mounted mine close to the throttle side. Got the IPhone 14 Pro Max Quadlock.
Did you go with the Pro or the Pro Large Mount? I have the same iPhone! miss not having navigation. Thought we would have had ACP by now! Wish BRP would tell us the truth what is going on!!
I went with an Arkon mount for my Garmin GPS.
The one that worked with my 2024 Spyder was their MC25MMB, which they say is compatible with a 25mm (1") diameter handlebar.
The MC25MMB mount is just the ring around the handlebars, and the post with the ball on the end. The rest of what you see in the picture came with the GPS.
