What does default code P1614 Mean?
If you have not had the throttle body update done, this code indicates that you will also now need a new throttle body, in addition to the update. If you have had the throttle body update done, the tech may have failed to perform the throttle position sensor reset properly.
That's the code that mine threw! :opps: Still riding it waiting for the new tire to get here so that several birds can be killed with 0ne stone at the dealers...
(If you have an erratic high idle upon startup; shut things down and give it another try! :thumbup:)
