What is this BRP harness extra connector actually for?
mneblett
Hi all - I'm currently installing the BRP hitch to my wife's 2021 Spyder RT-L. The attached pictures show an extra wiring connection in the harness (PN 710006904) that is not shown in the instructions.
With the RT's tail-lights plugged into the harness via their connections, and with the ignition on (both engine off and engine running), there is no voltage at the extra spade connector. Same when the brake is applied.
So the extra connection is not a switched +12V supply or a brake light supply. Anyone know what the extra spade terminal is for?
p.s. Kindly ignore the huge amount of under-skin dirt -- every time the RT goes out and returns it has to traverse 2.5 miles of (very) dusty gravel road :(
that should be power check to see if fuse in trailer power
Thank you for the suggestion. Unfortunately, this does not seem to be the case. I checked the RT's trailer fuse (F4 in the right fuse panel); it is good, and the contacts on the fuse show unswitched battery voltage at both sides of the fuse. At the rear spade connection, no voltage, whether ignition off or on. :(
Happy to take further suggestions. :)
My first suggestion would be to remove the tape from the wire and check the color code to the bike wiring schematic to find where it originates and that will tell you it's purpose.
I know it’s an old thread, but that red connector is for the 2024, and also need an additional harness called my24 in the instruction.
Perhaps as well for the 2025??
