Where is the gas tank vent tube on '20 RT?
Twofingers
Can anyone point me to the location of the gas tank vent on a 2020 RT Limited? A general location is fine. I just want to take off the least amount of plastic getting to it. I will be using it to connect an aux tank. If you have a picture, even better.
You will have to remove the passenger seat, then driver, then the panel that covers the tank & surrounds the dipstick. The lines to & from the gas tank should be visible on the right side, top. I don't have a pic of the right side showing the sending unit & lines, but here is one that shows the lines to/from the fuel vapor canister located under the side panel just inside the left sidecase release handle. Sorry for all the dust!
Hope this helps.
Hope this helps.
My, My, you look like you're having fun! Got her all undressed!!!:2thumbs: Mine looked like that a couple weeks ago. Plugs, wires and an air box mod!
