Where is the throttle harness connector for a 2025 F-3 Ltd Pedal Box install - can anyone help?
iw12surf
I apologize if this has been posted before, but where's the throttle harness connector? I'm installing a Pedal Box, and can't find the harness. I know it'll be a duh moment when someone points it out. Ryde safe. Ryde sober.
I don't know if this will help you. It's a video that the tech made of installing the heated grips on my 2025 F3-T. When he picks up the two wiring harnesses on the right hand side, I believe that one of those is for the throttle. It looks like it is buried deep inside the bowels of the bike.
After watching the video, it looks just like the installation on my 2016 F3L. But I learned after installing one on my F3T and decided to just let the control piece be underneath the top right panel. That way it stays out of the weather and is still easily accessible.
The throttle wiring on the 24/25 F3's and RT's does more that just control the throttle. It has taken the place of the Mode switch and the Reverse switch that previous years had. Make sure that both of those functions are working before you button everything up.
Thank you! Yes sir, definitely buried deep. Appreciate the vid clip!
