Windshield Install - do I need the metal sleeves?
ImaCaMan
My new windshield from Gustafson came today and when installing it, I found that two of the metal sleeves in the rubber bushings for the windshield holes were too small for the bolts to pass through. The other two were ok. I have left a message with Gustafson but don’t expect a reply till Monday.
I looked at the JRock shield I’m replacing, and it just has the rubber bushings without any metal sleeve, so I’m not sure I really need them. I installed it anyway and will drive it. What do you think?
This is a pic of one of the too small sleeves.
I would use them if I were you, there used as a limiter bushing, so you don't put too much pressure on the windscreen and cause a crack. Just my thoughts!
I wouldn't go without them either. I would be afraid of what might happen as a result in the future. Can you get a round file in there and remove enough material for the bolt to pass?
What Mikey and Bensonoid said, unless Gustafson can convince you otherwise and you accept their position.
It depends on the windshield.
The direction should tell you what to do if not, call them.
I recently replaced my 8 year old shield with a Freedom from Lamonster.
The Directions EXLICITLY state: Do NOT use spacers, rubber gaskets or screws and to discard them
They supply new "washers" and screws. Problem was leaving the correct space for molding.
I overly tightened and then backed off slowly until molding fit.
Has worked fine over the last several thousand miles.
AJ
My two round files were too big to fit. I tried to drill them out but wasn’t having any success. Since two did fit, I’m sure they will be sending me some more and hopefully I’ll get a fit for the other two.
As a final follow up, Gustafson's came through and sent me some replacement sleeves. They fit and windshield is now securely attached. Thanks for your input.
