10.25” Display, Apple CarPlay, miles to empty or fuel remaing
mecsw500
It seems whilst running Apple CarPlay on the 10.25” display there is no way to see fuel level or miles to empty.
Knowing this data whilst using a maps application is rather an essential piece of data to know, especially out here in the sparsely populated areas of the Western US where gas stations can be 100+ miles apart, depending upon the route.
It should have put that data on the left hand side of the screen at least in some form,.
I filed a bug report with BRP.
Fuel level? Looks to be on the left hand side at the bottom, next to the fuel pump symbol. To the left of the coolant temp. And can't that miles be switched to Miles To Empty?
That’s odd, mine doesn’t show that.
I’ll go through the setup again. Perhaps I configured something wrong.
Mine doesn’t have anything down there.
I’m on firmware V 5.1.0, I done know if that makes a difference, I’m going to do a reset and start again.
Thanks for the info.
Thank you, I reset my configuration changes and started again so I see what you see.
Several other oddities were fixed too. I think I had been messing so much with Bluetooth configurations and various other things it had got a little confused.
Now it works as it should. In full screen the fuel level was showing the same level before and after I filled the tank and would only start dropping after the fuel level went below what it was when before I filled it up. Now it shows full as the tank is actually full.
Thank you for the info. I’m much happier now.
