ordered the 2 up shock off brp wed site, cost 150.00 free shipping. Took 15 min to install. Here is how; Remove 2 nuts from shock bolts 15mm and socket is on a wobbly,not a universal swivel. 3/8 drive ratchet and 8 in extension, 15mm combo wrench for bolt end. Remove seat, there is 2 slots at the top shock bolt, wobbly on one end, wrench other(gotta kind of slip in there, easy) Lift bike with jack just enough to slide the bottom bolt out, then slide out top. Shock comes out the non belt side, easy. Bottom bolt first, then top. Blue locktite back together. Easy,Easy,Easy! tim move to how to section
