The plan this weekend was to get the spyder running. First task was to get the fuel pump into the fuel tank. What a hard thing to do! You have to devise a way to compress the fuel pump into the tank enough to put on the ring that holds the pump down. The fat oring that comes with the installation kit makes it extremely difficult. I ended up using a scissor jack placed between the fuel pump and my upper cabinets in the garage. Worked like a charm! Only thought of this after about an hour trying to push the fuel pump into the tank. Sorry no pictures of that setup, I was just to irritated to grab one. Main thing is that I got the pump in. I also installed the fuel tank into the spyder without any further problems.
Next was to perform a canistorectomy. The previous owner started to do it, but didn't finish. I bought that metal fuel filter and 4 feet of 5/16" fuel hose. Finished it up in a lickitysplit.
I found the fiberglass heat wrap that was hiding in one of my cabinets so I decided to wrap the header that runs along the left side of the spyder. I didn't have enough stainless steel tie straps, so I ordered some.
I also took a closer picture of the pulley and the surface rust. I rubbed my finger over it and no red dust came off of it.
Lastly, I installed a new seat cover. I really didn't like the diamond pattern upholstery so I took it off. The original vinyl under the upholstered cover was in decent shape, but I decided not to run it like that cause it wasn't up to my standards. Here is the new cover installed. Just need some time for the wrinkles to go away.
I also picked up the wheel from powder coat on Friday afternoon. I had to send back two of the wheels because they missed the inside corners, which were pretty visible. I should've taken pictures of it, but forgot. You can see a picture of the good rim in the first picture of this post.
On Sunday morning, my goal was accomplished. I filled the fuel tank with about 1.5 gallons of gas and started her up. On the first crank she fired up and came to life! No misfire, temps were good, everything seemed to work fine. Then a check engine light came on. I'll have to pull up that code to see what it is. The spyder did however run very nice. Very smooth and responsive. I think I forgot to tighten the O2 sensor, so I hope that wasn't the reason why the check engine light came on. The brake failure message came on, but that was to be expected since I didn't have any brake fluid in the system at the time of startup. Still waiting for the caliper rebuild that i'll be doing soon. Turns out, the calipers are the same as the rear caliper on a riot or revolt ATV. However, I think it only replaces the right caliper since they use one caliper in the back.
