S
spydeyblue
Guest
Our 2012 Spyder RT-S recently developed a loud squalling noise from the left front wheel. The cause of the noise turned out to be a defective front wheel bearing. I've attached a couple of photos of the defective bearing, which seems to have blown seals on both sides of the bearing. Our warranty covered the bearing replacement, thankfully. I thought I'd share what I learned about this particular bearing, just in case anyone ever needs to replace one, which isn't covered by warranty.
The front wheel bearing, Can Am part number 293350040, turned out to be a NSK 30BWD07, made in the US. Using the NSK number, I found a list of cross-references from other manufacturers:
KML - 633313C
SKF - BA2B633313C
FAG - 529891AB
Also, according to this post on a Can Am ATV forum, All Balls Racing sells the same NSK 30BWD07 bearing as their part number 25-1516, for around $25, versus the Can Am price of $75:
http://www.can-amforum.com/forums/atv-tech-tips/28669-best-deal-wheel-bearings-24-vs-69-dealer.html
Enjoy the ride!
[TABLE="width: 71"]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
