Isopedella
Well-known member
2017 F3 .
So I have just fitted up a new set of front tyres. They were balanced and the wheel nuts torqued. Then took it out yesterday for a run. I noticed a noise from the front right. Ok until around 100kph or so. Sounds a bit like a playing card on bicycle spokes. Constant whirring/flicking sound. Goes away when I slow down.
I thought first I would swap out the fronts and see it the noise moves to the left. Check the pressures are correct.
While the wheel is off I will I will also inspect the inner side of the guard for any sign of rubbing, despite there appearing to be plenty of clearance with the 165/60 R15 just fitted.
Also have a look at the hub. The inner plastic cap was missing when I got it so. No idea how long it was off and it has been remedied with a new inner cap. I did not dis-assemble and repack with bearing grease at the time. Im thinking maybe the bearing needs attention.
The nut with the pin through it, I suppose that if removed allow access to the bearing? Maybe the hub pulls off?? Dunno yet.
Just outta bed and having a cuppa and thinking on this, thought I would share them. Maybe get some tips for later on.
I did have a surf here and ob the u-tube but found nothing on that hub and bearings. So if your aware I would appreciate where to locate it.
