2013 Can-Am Spyder RT Safety Recall - Elevated Temperature in Engine Compartment
RT Fix?
I hope they have a fix that will actually work, I would like to actually ride my Spyder instead of it being a centerpiece for my garage.
I am impressed with Can Am for this step!!
Hopefully all those with these problems will now find relief.
my 2 cents worth
Your impressed because the NHTSA forced them into a recall situation?
Frankly it should have been investigated and repaired over a year ago. Not 2 model years later and after being told repeatedly it was all in our heads that there was nothing wrong with the bikes.
Yes, I am glad to hear something is finally in the work. But again wait a few months and we might do something. I will believe its a real fix when I see it work. Until then, I really think this 'voluntary' business is yet another attempt to stave off having to do much of anything. Hope I am wrong, but its the way we have been treated so far. They also better be willing to update any of the 2013s that have already had work done to them by the owner trying to make the bikes safe and usable while waiting for BRP to get around to doing something.
I actually hope its body panels, an insulated gas tank and retrofit of the reversing fan from the 2014s.
Thanks to one police department incident report and NHTSA
Short of that single incident(the cops spyder), and one other conveniently linked to it. Nothing would have gotten better. imo
Failure to support what one sells is why we are forced to have BIG BROTHER looking out for us.
Hope the fix works for all who own 13's. :doorag:
Don't get too exited about this. I think it is the same thing I was a a volunteer for in August.
1. One exhaust shroud
2. Drilled 50 holes under seat at the rear
3. Side vent deflectors (which I had already bought)
4. Reverse the fan below 6 MPH
This did absolutely no good to solve any of the Heat or Gas fume problems for those of us who participated in this experimental program for BRP.
After Pitbull deleted the CAT and the above program did nothing I traded for a 2014 with none of the Heat and Gas Fume problems. This Major design problem will never be solved by all these Band Aids. It Will take a Major Design change or retrofit with the 1330 engine that BRP is not willing to finance. Meanwhile they will continue to string everyone along and give them false Hope IMHO. I do have a licensed flight and mechanical engineering back ground but by no means am I an expert.
A lot of money has been wasted by owners trying to solve BRP's mishap. The 2013 RT was to have a new frame and the 1330 engine and 6 speed transmission. At crunch time the 1330 Engine and Transmission were not ready. BRP decided to use the 998 engine in the new frame designed for the 1330 engine. There in lies the major problem. The 998 was barely able to fit properly due to the higher frame and less space and placing the exhaust and engine too close to the gas tank. It was this decision that has caused all the heartburn for a lot of us and cost us an arm an a leg. For those in the northern climes the problem is less due to the lower mean temps. BRP told us this as we were doing research to try to solve the problem and learned the problem was worse on the 2013 than the 2010, 2011, 2012.
Jack
Hi jaherbst,
Thanks for your comment. While we can't go into detail just yet, I can assure you what we've been working on is not what you describe above or some sort of band-aid fix, but rather a viable solution which is now in the final validation phase. BRP is fully committed to getting all this deployed with as little delay as possible. We'll be able to provide more info shortly.
Jack
Jack,
Don't hold back Man, tell us how you really feel.
Having said that, I am glad I have a 2012 RT so I don't have this problem. Owners who have had to spend their own money to fix this problem should be reimbursed, especially since BRP has admitted, or forced to admit, that there is a problem.
Jack
after reading this BRP said, WELL THERE GOES THAT IDEA we need to try something else now because jack laid out our fix. i spent and lost a lot of money on my 13 rt and even thou i now i have a good bike with the 14 i still hold a lot of anger for what i went through and the beating i took in the loss of money.
Question
BRP,
i for for one love my 2013 RTL, just under 20000 miles in a year and a half and I expect to put a lot more on it this year. We have plans for some long trips this spring and I was hoping that we can get a slightly better Idea of when the fix will be available, and how much shop time will be involved in the fix. Thanks for taking the time and and investing the resources to find a solution to what fortunately has been a tolerable issue for me at least. My wife drives the Spyder too and she has had some minor burns on her legs from Ryding but that was resolved by her wearing some riding pants.
Again BRP, thanks for stepping up, and I sure I will take some grief from the haters on this board but I love my Spyder and I look forward to more awesome times on my RT.:yes::yes:
Hello,
The timeframe mentioned on the Transport Canada page for the recall is by May; and we don't anticipate it being any different for the United States. As for shop time, as soon as there's an accurate estimate available I'll post it here.
As I've said before, it takes a lot of time and effort to (1) find the root cause of a problem, (2) develop a fix that works, and (3) validate the fix. This is a serious issue, and like the 2014 ST, the fix will be adequate.
Once the issue becomes formalized, MORE time is required to develop a fix, not less, as more testing and paperwork is required.
While we know the frame & radiator design change, coupled with the 990V-twin) in 2013 was a significant factor in the increased heat for the 2013 RT, there may have been other changes that impacted air flow and may have had a significant impact, or mechanical changes, such as additional timing changes to meet emission requirements, and adding additional heat.
Let's give BRP the benefit of the doubt, and see if they get it right.
Thanks Jack, well spoken
BRPcare,
I am an Australian 2013 RT ltd owner. Our temperatures for 9 months of the year is above 25 Degrees C, our winter temps are around 19 Degrees C tops, I live in South East Queensland, the best place in the world. When I purchased the RT in December 2013, I rode home from the supplier in 40 Degree C temps and I knew then I had an issue. The issue was not enough to stop you riding but it made what should be enjoyable very unpleasant. I retired six months after I purchased the RT, I love the Spyder and hope to get many years out of touring on it.
After several months of looking for solutions and doing some of the things that have been posted on this forum, I decided to buy an after market filter from our local supplier and investigate ceramic coating the pipes and the cat. I was advised that this would void my warranty and have decided to wait until it is run out.
I then approached BRP Australia about the issue, my major concern was boiling fuel and gas fumes of which I had plenty. They directed me to the supplier and he made some changes to the RT, mainly changed the purge valve and the canister, this has made no difference.
I would like to think that BRP will fix this issue and not as Jack has intimated, band aid it.
BRP have a great product with many dedicated owners who love their rides as my wife and I do. We are off to Tasmania on Sunday 22[SUP]nd[/SUP] Feb, for a 5 week touring holiday on the RT. It is a pity that this could not have been dealt with sooner but I understand the ramifications of dealing with such an issue.
I look forward to a solution, love the Spyderlovers forum and love my RT, lets hope it all works out for the best.
pjb_Brisie
Hello pjb_Brisie,
I then approached BRP Australia about the issue [...]
This safety recall addresses all 2013 Can-Am Spyder RT vehicles regardless of country of operation. It will be carried out worldwide.
That sounds like an incredible tour. Have a safe and wonderful holiday!
Hi 03hdjill,
This recall addresses an issue occurring on the 2013 Can-Am Spyder Roadster RT models. Due to differences in airflow within the engine compartment, engine configuration and various other factors, only 2013 Can-Am Spyder Roadster RT models are included in this recall.
will this take care of the gas fumes ?????
2013 rt limited
bought 2013 rt limited in may 2013.
8500 miles to date.
2 yr warranty at time of sale
is BRP going to cover any and all expenses even after my warranty expires?
I have a 2012 RT with the strong gas fumes issue. I know 2012 models are not part of this recall. Anything further expected for those with earlier models and the gas fume concerns?
Hi lenlis,
This is a safety recall. Your dealer will do the required repairs under this safety recall at no charge to you.
If we had a "Me Too" Button; I'd be all over it!
Give them a chance to implement the corrective actions... :thumbup:
Or... Do you just like to hear yourselves complain? :shocked:
(I just KNOW that this is gonna start something... But it HAD to be said!)
